RDK-91 transformer
Posted by: OCR on
Question about RDK-91: The transformer used for this power supply is YW-360-02B by Yih-Hwa Enterprises or SNX-R1380 by Santronics. Is there a more common substitute I could use instead? Its ok if the shape is different. DiGikey sugests their part # 732-2250-ND, but the price on it is over $15 for quantity one. Could you sujest somthing more common in the lower price range?
Submitted by PI-Terry on 11/19/2013
The transformer used in RDK - 91 is a pretty standard core PC40EE25-Z from TDK, and the bobbin is EE25, Vertical 10 pin from Yih-Hwa. They are already very common. If you need a good price, you could contact some other transformer manufacture directly instead the digikey, which basically only good for purchasing some test samples.
Hope this is helpful.
Submitted by imranahmed on 05/31/2020
Dear PI-Terry,
Please recommend me only direct link for buying SNX-1380 Transformer?
Imran
Submitted by PI-Lupin the Third on 06/01/2020
Hi imranahmed,
Good day!
Upon checking the system, I am not sure if PI-Terry is still around. If may I suggest, please kindly create a new ticket for this then I will re-delegate your inquiry to one of our engineers.
Hope to hear you again.
PI-Lupin the Third
Submitted by imranahmed on 06/02/2020
Dear PI-Lupin the Third,
I found and corresponding with Santronix team.
Imran
