Max output voltage
Posted by: tolisn on
Hi.
What is the maximum output voltage that can be derived when using the TNY268 ?
Submitted by VCastrellon on 10/22/2013
Your question does not have a straight answer.  It depends on many factors.  Conveter topology,  Vin, Controller DRAIN Voltage........
If you tell me what you are trying to do I may have an better answer.
Submitted by tolisn on 10/22/2013
Hi.
I'm trying to make a power supply that has the following:
Vin=230VAC
Vout=230VDC
Pout=15W
Submitted by VCastrellon on 10/23/2013
I can think it is possible to use the controller in a design in a  buck topology. However we do not have any possible experince for your particulat application.  It would be hard for us to give your support in case you need it.
