TOP255PN
Posted by: dayatin on
with ref to attached schematic, output starts oscillating at 50% load, dont no why? need help, even though heatsink is installed.
Submitted by PI - Traveler on 08/31/2012
The first thing I think of when I hear "I have an oscillation" is that something isn't setup correctly with your control loop.
Have you verified your power supply control loop and asessed your gain/phase margins at different input voltages and load conditions?
Also, I can't see your schemetic very well.  Please create a PDF and attach that directly.  Also if you have you PI Expert design files, attach those.  If not, please give me the input and output specs of your design as well as the documentation on your transformer construction.
-The Traveler
Submitted by dayatin on 09/04/2012
5V out put dips to zero suddenly when i apply 60% load, it works fine upto 50% load, above which output dips, i have attached pdf file of my schematic, and transformer design files. I dont know what is the problem.
Primary Inductance  Lp 1194.523985 μH
Core Type   EF25
Core effective cross sectional area Ae 0.525 cm²
Core effective path length Le 5.75 cm
Core ungapped effective inductance Al 1850 nH/turn²
Bobbin Physical Winding Width BW 15.1 mm
safety margin M 3 mm
effective bobbin width Bwe 18.2 mm
outside diameter of the primary wire OD 0.259518519 mm
insulation thickness INS 0.0486016 mm
Bare conductor diameter DIA 0.210916918 mm
American wire guage AWG 31.69938734
effective cross sectional area in circular mils CM 68.60321203 Cmils
  cma 211.9673499 Cmils/A
current capacity for magnet wire CMA 212.5926727 Cmils/A
maximum flux density in the core Bm 2451.147174 Gauss
AC Flux Density for Core Loss Curves (0.5 X Peak to Peak) Bac 1225.573587 Gauss
core gap length Lg 0.2360653 mm
Submitted by PI - Traveler on 09/10/2012
You feedback circuit components seem generally correctly.
I did notice that your bulk caps on the 5V output seem a bit low.  You have 660uF of caps...I would try doubling that.
Also, with the turns ratio you have, primary inductance, etc, you might be in saturation territory for that transformer.  I would double check your design  and verify drain current and voltage waveforms during operation.
-The Traveler
