Auxiliary Power Supply
Can you recommend a PI switcher for an embedded 12V Auxiliary Power Supply. AC or rectified DC input available
sir, can you please provide me a multiple output(5v and 12v) supply having inputs 40v to 80v dc(from pv panel).
Thank you
Hi Ansul,
Could you provide total output power requirements as well as the output currents for each output?
My Design Specification are:-
Input - 40v to 80v (pv panel)
Output 1 - 5v and 0.6 amp
Output 2 - 12v and 0.2 amp
Output power - 6 watt
Must be Isolated Topology
You can refer to DI-152. I am attaching the link below:
https://ac-dc.power.com/sites/default/files/PDFFiles/di152.pdf
You would have to design your transformer using PIexpert to make sure that the temperature will run at an optimal temperature.
If you dont have the PIexpert yet you can get it from this location:
https://ac-dc.power.com/design-support/pi-expert/
The information you've provided isn't sufficient to make a product recommendation. Can you please provide your input/output specs at a bare minimum?
-The Traveler
