Design spreadsheet in AN-17
Posted by: XYZXYZ on
For the spreadsheet mentioned in AN-17, where can I find or download it from your website? Or if possible, can you email it to me? Thanks a lot.
Submitted by PI - Traveler on 10/25/2011
XYZXYZ -
The spreadsheet you're referring to is the PI XLS design spreadsheet in our PI Expert software. The one snag you're going to run into though, is that AN-17 refers to an original TopSwitch product that is no longer supported by our software PI Expert. We still manufacture (in very limited quantities) some of our earlier TopSwitch products...but if you're working on a new design, I would highly suggest moving to one of our newer TopSwitch (JX, GH, HX, etc) parts that are supported by our software.
If you tell me about your power supply design specs, I might be able to steer you towards the right product for your application.
-The Traveler
Submitted by ravji on 02/26/2024
I have much quantity of TOP224yn.If possible I request you to provide PI XLS design spreadsheet .
pipliaravji@yahoo.co.in
For TOP220yn modules ,ETD 29 core transformer winding as under
winding between 1-2,  3-4, 5-6,  7-8,  9-10,  11-12,  13-14 are as follows,
start pin1 9turns                end pin14
end pin2                               start pin13 15turns
start pin3 80turns            end pin12
end pin4                              start pin11 15turns
start pin5 9turns            end pin10
end pin6                              start pin9 15turns
start pin7 15turns            end pin8
