Clamp Circuit,Values of R,C
Posted by: sheldon on
i have been through your application note AN 47, The idea i need to know here is the selection of values for R and C, for instance if we are using RCD clamp circuit then how will you decide the values . For instance if you consider the circuit of LNK 353/354, here we get started by choosing the value of either the resistance or the capacitor and selecting the frequency (here comes the problem, whether i have to choose the switching frequency of the device or the line frequency of 50/60 Hz),If i were to choose the switching frequency of the device can i choose the typical oscillator frequency of 200 KHz for LNk 353/354 device )or is there any other technique that i have to use,, please Help in this Regard
Thanking You
Submitted by John Carpenter on 04/06/2011
I would recommend using our free design software (PI Expert)to aid you with your design. If you are interested in estimating a RCD clamp circuit, follow this procedure.
To find the resistor value:
R = (V^2)/(1/2*LI^2F)
where:
V is the average voltage on the clamp capacitor
L is the primary leakage inductance
I is the peak primary current
F is the switching frequency
for example:
If the reflected voltage on the primary (VOR) is 100 Volts (Vout*Npri/Nsec)and you want the average clamp voltage to be 125 volts above this, then: V = 225 Volts.
This voltage must be above VOR and this voltage plus the bus voltage must be less than the desired peak drain voltage. If the bus voltage is 375 volts and V is allowed to be 225 volts, then the peak drain voltage is 375+225= 600 volts.
If the leakage inductance is 10 uH and the peak drain current is 2 amps. In this example the switching frequency is 100 kHz.
Then: R = (225^2)/(1/2 *10uH * 2^2 * 100 kHz) = 253 k Ohms
C is estimated to be C = 10* (L *(I^2)/(V^2)= 10*(10uH *2A^2)/225^2) = 7.9 nF
This gives you starting values, check your design under all operating conditions for safe peak drain voltage.
Z. Cochrane
Submitted by sheldon on 04/10/2011
Thank you very much... Your Design guide was very helpful.,
Submitted by Rashmi B on 03/23/2017
I want the equation to calculate the r and c value in a RCD clamp circuit to reduce the overvoltage. The expected dc bus voltage is 680v and the overvoltage obtained is 1600v
Submitted by PI-Traveler on 04/06/2017
Hi Rashmi B,
Thank you very much for choosing Power Integrations.
Could you please provide me with additional information regarding your power supply design?
1. Application of power supply?
2. Isolated or non-isolated
3. Input voltage range?
4. How many output voltage rails?
5. Output voltage and current for each rail?
6. Continuous output power
7. Peak power requirement if any?
8. Preferred PI part?
Submitted by Rashmi B on 04/17/2017
In reply to by PI-Traveler
Input voltage is 480v, non isolted power supply and i dont have other information. I am designing the parallel RC clamp circuit across the dc bus link capacitor of adjustable speed drive to reduce the overvoltage across it.
Overvoltage failures.pdf (1.05 MB) 1.05 MB
Submitted by PI-Traveler on 05/01/2017
Hi Rashmi B.
May I know what topology is used for your PSU? If you have a working schematic, I could help your review your design as well. In any case, I am attaching a document which can help you in sizing your clamp.
PI-DG-101_ClampSizing.pdf (240.42 KB) 240.42 KB
