Testing of a top switch
Posted by: Mohamed on
sir,
Can u pls tell me the procedure to test a top switch
regards
sabir
Submitted by VCastrellon on 08/27/2010
You can see Figure 33 on the data sheet of TOP JX for the set up to test This TOPSwitch family.
Submitted by Mohamed on 08/28/2010
Sir,
i measured the voltage at the control pin found 5.6VDC and the voltaged across the Switch is 325VDc.also for testing purpose grounded the X and L pin.No output at the secondary availble.can i suspect the top switch??
Awaitng your kind replay
Sabir
Submitted by Deepika on 07/24/2017
Sir,
Can u tell me how to test a top switch from top-HX family.
can we test the TOP switch alone without any circuitry?
kindly reply.
Submitted by PI-YY on 07/25/2017
Hello Deepika,
Thank you for interested in Power Integrations products.
To begin with, can I ask what kind of test you are going to do with top-HX family alone and why you need to do those test
Best Regards
