Testing of a top switch
Posted by: Mohamed
sir,
Can u pls tell me the procedure to test a top switch
regards
sabir
Sir,
i measured the voltage at the control pin found 5.6VDC and the voltaged across the Switch is 325VDc.also for testing purpose grounded the X and L pin.No output at the secondary availble.can i suspect the top switch??
Awaitng your kind replay
Sabir
Sir,
Can u tell me how to test a top switch from top-HX family.
can we test the TOP switch alone without any circuitry?
kindly reply.
Hello Deepika,
Thank you for interested in Power Integrations products.
To begin with, can I ask what kind of test you are going to do with top-HX family alone and why you need to do those test
Best Regards
You can see Figure 33 on the data sheet of TOP JX for the set up to test This TOPSwitch family.
