LNK302 and LNK362
I have it hard to find LNK302P. So I used LNK362P instead. It seems to work but I have a 300mW no-load power consumption (unisolated high side buck opto feedback).
Is it safe to use LNK362 instead of LNK302 in this config?
Would the no-load power consumption decrease if I used LNK302P instead ?
Pierre.
Hi:
I'm new to PI forum so I appologise if I'm writing on the wrong place.
I'm using LNK302 with 230V~ input to produce 24VDC to supply a light switch. When switching inductive loads (e.g. ferromagnetic ballats) the module explodes. Attached is the schematic. If I use a normal RC power supply it works fine and never blows up. How can I protect the circuit? I prefer using LNK302 because I need universal power supply range (110 to 230 V~).
Any help is welcome.
| Schematic.pdf (20.92 KB) | 20.92 KB |
Yes, you can use LNK362 instead. There should not be much difference in no load input power.
thanks
PI-Sarek
The LNK-302 has fewer functions as compared to the LNK36X family and so the LNK302 should have less no load consumption.
