Simulation Models
Hello everybody,
I know it's an old post. But I have the same question like Adam White. Does meanwhile anything happen on this?
Kind regards,
Patrick Hensel
Hi Patrick Hensel,
Sorry, but we don't have pspice model for TopSwitch.
Jedidiah
Hello sir,
I wnat to know what is the lowest and highest dc input range of link switch lnk304-06 ic.
Hi Sourabh,
If it's for flyback topology, the minimum DC input should be >70V. For the maximum DC input, it depends on your design as long as it does not hit the maximum Drain to Source voltage of 700V. If you have DC input voltage of 500V, the stress on the voltage across Drain to Source can be as high as 688V which is almost near the maximum rating of 700V. (This is considering you have output voltage of 5V with 0.5A output current). Turns ratio between primary winding and secondary winding must also be considered to avoid hitting 700V maximum rating.
Jedidiah
Hello Adam,
I'm afraid at the moment we do not. However can you share your interest in modeling? If there is a lot of interest in modeling its something I'd like to understand.
Cheers
Chekov
