Output voltage is Fluctuating
Why Ouput voltage is flucuating?
Any comments to fix the issue
Please see attahced schematic,
Output are not constant.
Please advise why most of the time on I have seen in several desing with differnt packages that output do fluctuate
waht is the common issue that it does.
| PSFET-23000244-71V-2A- Rev-1B-Schematic.pdf (85.54 KB) | 85.54 KB |
Hi Saleem
Is your question came from the issue as with banshi or this is a new inquiry?
When you mention several designs, are you referring to those made by Power Integrations? Can you provide a waveform describing the fluctuations of the voltage output? The reason can be from many factors like high input ripple from low input capacitance affecting the output, feedback not properly working, can be high frequency ripple, poor transient response, etc...
PI-Picard
